    Lock an object with password?
    8 Posts 4 Posters 669 Views 4 Watching
    • deaneauD
      deaneau
      hello,
      i search a way to lock objekts /groups/scenes via password.
      the normal function "lock object" exist in GS. exist an plugin to do this with password?
      thank you
      Dean
      MADE, BORN AND LIVING IN BERLIN
      Big Thank You to all Programmers
      Some German words are so long that they have a perspective. M.Twain
      • tbdT
        tbd
        no. not possible in current version.
        SketchUp Ruby Consultant | Podium 1.x developer
        http://plugins.ro
        • deaneauD
          deaneau
          thank you for your answer
          • TIGT
            It could be done using a complex set of attached attributes and linked observers that'd prevent unlocking of a specific group/instance - but it's easily thwarted if the rb loading that code is disabled at startup.
            Other 'raw' objects are not 'lockable' in the same way.
            Layers are also not 'lockable', and although coding attributes/observers to ensure a layer isn't deleted [e.g. if deleted reinstate and add all entities back to that layer etc etc] might just be possible but it'd be veeeery convoluted...
            Why are you interested in doing this ?
            My head hurts just thinking about it............
            • deaneauD
              deaneau
              @tig said:
              It could
              i work on an historical project, some buildings will be payware and the scene is freeware.
              • TIGT
                I think you must consider other alternatives like 3D PDF or QTVR or Flash-based panos etc
                • deaneauD
                  deaneau
                  how i can export from SU to 3dpdf or QTVR?
                    SimLab have a plugin that exports to PDF
