    Lighting. LED Tape
    7 Posts 3 Posters 564 Views 3 Watching
    • Z Offline
      ziomke
      Hello. My problem is to add lighting something like "strip" the LED. In rendering showed the place. The idea is to add to the back of the item marked "X" some lighting along the whole length to shine on the wall (also marked on the brown wall)
      http://img39.imageshack.us/f/tv11.jpg/
        Hi Zionke,
        What rendering software is that?
        Anyway, here is a topic where we discussed this the other day:
        http://forums.sketchucation.com/viewtopic.php?f=15&t=34322
        it seems that best is to use a single plane as an emitter and where it is black, it will not emit light.
        Any kind of led light will e very subtle in this rather well-lit room however.
        • jgbJ Offline
          jgb
          Hey Big G, that is a far superior avatar than that goofy replacement of your old (and pretty good as well) green animated avatar. πŸ‘
          jgb
            Well, a golden coin of Caesar Caligula is always a cool thing. πŸ˜†
            • jgbJ Offline
              jgb
              You are always Gold with me. β˜€
              jgb
              • Z Offline
                ziomke
                I'm using Kerkythea. Could someone show it at a simple example? I am a novice. As for this topic is not found an answer. Thanks
                  In that topic, where I posted those "fake" led lights, I was using Twilight Render which uses Kerkythea's rendering engine. So it should work the same in Kerkythea, too.
                  Have you got a led pattern that you would like to display? (Note that it would be very slow rendering if you wanted to place individual lights there)
