    Vertical images
    8 Posts 4 Posters 2.2k Views 4 Watching
    • pietervP
      pieterv
      Hey,
      I have a problem. I don't know how to get the maximum resolution out of an image that will be printed on a large scale in a vertical way. Sketchup turns out to be oriented horizontaly primeraly. The print will be 165 centimeters high and 68,5 centimeters wide. I figured out that the maximum resolution I can get with V-Ray is about 9000 x 6000 pixels.
      When I render the scene horizontaly, I get this result:
      http://users.skynet.be/fb517223/sketchup/resolutie_doorsturen_01.jpg
      A lot of space is lost this way on the left and the right side. When I do it verticaly with the exact same scene in sketchup, I get this:
      http://users.skynet.be/fb517223/sketchup/resolutie_doorsturen_02.jpg
      For some reason it zooms out a lot this way. I could zoom in before I render and adapt the field of view value but I don't think this is a very practical way of working. Also, by changing the field of view, my drawing changes.
      This is what the scene looks like in sketchup:
      http://users.skynet.be/fb517223/sketchup/resolutie_doorsturen_03.jpg
      Does anyone knows a solution to this problem? Many many thanks in advance!!!
      Pieter
      This is my website:
      Citypixels - 3d Visualisatie Architectuur
      • honoluludesktopH
        honoluludesktop
        As long as you don't require the horizon, and can somehow adjust the shadows, how about rotating the model on its side.
        • pietervP
          pieterv
          That's a good idea, but the light is good now and I think it will be very difficult to make it the same as it is now. But I thought of something else: I can tilt the camera/ view with the Ctrl key held down. It's not easy, but once I got it right I can make a scene out of it. Thanks anyway!
          This is my website:
          • GaieusG
            If a simple tilr would help, how about this plugin then?
            http://www.smustard.com/script/CameraControls
            • pietervP
              pieterv
              That plugin comes in very handy! Thanks a lot Gaieus!! πŸ˜„
              This is my website:
              • thomthomT
                If you set the aspect ratio in SU you can make VfSU match it. So you should be able to render a vertical view without the wasted pixels.
                You can use my V-Ray Toys plugin to set the aspect ratio. (Ignore the stuff about the zoom - that's aimed for older V-Ray versions that needed some tweaking to make the views match.)
                • pietervP
                  pieterv
                  Thanks a lot Thomthom! Your plugin have worked just fine!
                  This is my website:
                  • GaieusG
                    Ah yeah, that's easy with some TT plugins...
                    πŸ˜’
