    Disappearing Icons
    4 Posts 2 Posters 775 Views 2 Watching
    • gtalaricoG Offline
      gtalarico
      Has anyone experienced this?
      (It started after SU 8.05 patch)
      Notice the Freedo Scale Toolbar for example.... Only half of the icons are shown!!!! This is driving me crazy.
      Ironically, I think this happens every time after I use the "restore toolbars"... πŸ˜†
      http://img52.imageshack.us/img52/1503/screenshotes.th.png
      Uploaded with ImageShack.us
      -Gui
      http://www.gtalarico.com
        I cannot open your image (imageshack 🀒 ) but I know what you mean. This is actually pre-patch and you can fix it by first undocking the toolbar and then re-docking it again. Can be a pain in the @rse but unless you need to restore your toolbars too often, not a very big issue actually.
          gtalarico
          I usually fix it by closing sketchup and opening it again... I have too many toolbars to dock and undock!
          And yes, i have to use "Restore" often because I have a dual-monitor setup @ different resolutions, so if I move SU to the small screen, all the toolbars get messsed up : )
          Sorry my image made you puke πŸ˜† ! How do you recommend I share images around here?
          -Gui
            Sorry, it was not yourimage but Imageshack. It loads extremely slowly (probably also depending on geographical location) or for some, it does not load at all. Then if it loads, it gets embedded in that website where eventually it displays very small...
            Anyway, best is to attach it straight here (below the text area you type your message). This also have the advantage that it will remain here (unlike images of some people who delete them from time to time on external sources).
            Your tip of closing SU and reopening sounds interesting; πŸ‘ next time I'll try (I also have more than enough toolbars - in 5 rows above my SU screen).
