    Windowizer 4 and 1001 bit tools' devide panel conflicts
    5 Posts 5 Posters 1.2k Views 5 Watching
    • N Offline
      nicasiojoel
      Hi everybody. I recently installed windowizer 4 plugin. I Have also 1001 bit tools plugin already installed in my PC. I found out now that the devide panel of 1001 bit tools does not work anymore. These two plugins are very useful. Can anyone help with this please?
        Have you tried contacting 1001bit support?
        • jim smithJ Offline
          jim smith
          I have windowizer4 and 1001 bit pro installed. I just tried both plugins in the same SU window and they work together just fine. I tried some of the other 1001 buttons like louvers,grilles, random openings hip roof etc and they all work.
          "Out of clutter find simplicity,
          from discord find harmony,
          In the middle of difficulty lies opportunity"
          Albert Einstein
            saturne45
            Hi, I had the same problem as you, but my conflict came from "multiface offset", 1001 bit and windowizer works good.
            • rkoehn7341R Offline
              rkoehn7341
              Windowizer will only work properly if the face is absolutely on axis. erase two of your edges and re-align and it should work just fine.
