    How to receive the size of a line Sketchup rubi
    6 Posts 3 Posters 2.0k Views 3 Watching
    • Z
      Z11
      ruby script draw square
      model = Sketchup.active_model
      entities = model.entities
      pt1 = [0.m,  0.m, 0.m]
      pt2 = [10.m, 0.m, 0.m]
      pt3 = [10.m, 10.m, 0.m]
      pt4 = [0.m,  10.m, 0.m]
      new_face = entities.add_face pt1, pt2, pt3, pt4
      How to receive the size of a line Sketchup rubi ?
      • TIGT
        The len=edge.length returns the length in inches, len.to_m returns it in meters.
        In your example you know the length from the code but the len= method works for any edge...
        So face.edges.each{|e| puts e.length.to_m} would print the length of the face's edges - in your case 10m ...
        • Z
          Z11
          I should draw simply in model a dimensional line.
          What method Sketchup to construct a dimensional line
          • thomthomT
            No access to dimensions via the Ruby API. 😞
            • Z
              Z11
              Thanks for the answer.
              It is a pity.
              • TIGT
                You CAN sort of fudge it... make a separate SKP file containing a dimension 1" long and 1" offset.
                Then in code load it as a component into your SKP.
                Add an instance at a point and scale it in the X to match the length to another point and in the Y for the offset needed.
                You also need to transform-rotate it so that it aligns with the vector of the two points etc...
                When done you can explode the dim-component instance back into a plain dimension.
                An dims added this way will ever be linked to an edge or vertex as in a manually added one...
                You could perhaps include a 1" long edge in the dim-component that the dim refers to... and if that then replaced the original line below it when exploded it might keep some linking ?
                It's better than nothing... but only just... πŸ˜’
