    Transformation help
    2 Posts 2 Posters 296 Views 2 Watching
    • K
      ktkoh
      I have a point in a component's local axis and want to transform this into a second component's local axis.
      My thinking is that I would need to transform this from the first local axis to the global axis and then from the global to the second local axis. I looked at the component instance class but could not decide how to use the transformation functions to do this.
      Keith
      • thomthomT
        <span class="syntaxdefault"><br /></span><span class="syntaxcomment">#&nbsp;pt&nbsp;=&nbsp;point&nbsp;in&nbsp;group1<br /></span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform</span><span class="syntaxkeyword">!(&nbsp;</span><span class="syntaxdefault">group1</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">inverse&nbsp;</span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">pt</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transform</span><span class="syntaxkeyword">!(&nbsp;</span><span class="syntaxdefault">group2</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">transformation&nbsp;</span><span class="syntaxkeyword">)<br />&nbsp;</span><span class="syntaxdefault"></span>
