    Program crash
    2 Posts 2 Posters 208 Views 2 Watching
      Basslady
      I am really new to Sketchup, but have been able to create an item for in my home design program. However, every time I try to load it into the program, the program crashes. I know Sketchup skp files will work, since I did download a couple from Google 3D Warehouse,and they load just fine. Any suggestions as to what I may be doing wrong?
        mac1
        Are the good vs bad of similar complexity and the same version of SU? When you import to another program the inport filter may not be designed to handle the version. check the drop down box on the save as menue and it should show different SU versions. Maybe try an older one??
