    Search for Plugin to copy once and serial-paste function?
    2 Posts 2 Posters 316 Views 2 Watching
    • T
      trunix
      search for Plugin to copy once and serial-paste function?
      hello friends,
      I'm searching for a helpful Plugin/or Function in SU 8 to take ohne objekt/Line or what ever, to paste/put in a exactly
      number of a serial in a line or circle or what ever.
      For example:
      I'm building different cabinets/furniture on SU, so I have to distribute/copy-paste allways Doors/Sides/shelves
      in e spezific space/high oder deepnes.
      I draw the objects / groups / component and would like to distribute them at regular intervals, for example in line, rectangle or circle
      or what ever in just a few clicks.
      I think this need is not only my?
      Thanks very match for a info/plugin or idea.
      trunix
      • TIGT
        You can already do this in a line using the existing Move-Tool +Ctrl for 'copy', pick or type offset, and then immediately type x6 to make six copies at the spacing of the first or /6 to make six copies fitting within the over all distance you picked.
        Similarly for a radial array use Rotate+Ctrl and a picked or typed angle with x6 to repeat six copies each with that angle or /6 to fit six copies within that over all angle...
        There are tools like Component-Stringer that will distribute copies along paths etc if you want more complex alignments or scaling as you go for example...
