    Dimension tool not sensing SU model within LO
    layout
    5 Posts 2 Posters 1.0k Views 2 Watching
    • keea1111K Offline
      keea1111
      Has anyone ever had the dimension tool simply not sense the SU model, and won't lock into the vertex.  So I have to guess the exact vertex and then drag to the next.  This is not working out so well.  I tried to move my model to the front, making sure nothing is covering the layer.  I haven't had this issue before as I recall.  Unfortunately at a standstill with this drawing.  I'm sure it is something simple I'm missing...thanks,
      KEEA
        bjanzen
        OK, the cases I can think of:
        1. You turned off Object Snap. Arrange->Object Snap.
        2. We had an old bug that if you got a center inference, you'd lose the ability to get any inferences after that. That bug was fixed in the current versions of LayOut: 3.0.4010(Mac) 4811(PC).
        Anyone else? It's definitely not an image?
        b
          bjanzen
          er, Mac = 3.0.4810.
            bjanzen
            One other issue is getting an edge through a section cut, but that doesn't sound like your concern? If it is, search this forum for the answer.
            b
            • keea1111K Offline
              keea1111
              Thanks Barry...I rebooted the computer, and came back on fine....
              KEEA
