    Some plugins don't appear
    4 Posts 2 Posters 346 Views 2 Watching
      deanlegg
      Hi I have installed a number of plugins and they are all in my plugin folder but some don't appear in the plugin or toolbar drop down
      Also I cant get TIG"s extrusion toolbar, but its in the plugin drop down....any ideas?
        Check that you have installed the files retaining their subfolders.
        Many complex scripts have one or two rb files in Plugins and then lots of other files inside their subfolders to make toolbars, web-dialogs and the like...
        Mis-installing is the usual cause of this type of problem πŸ€“
          deanlegg
          Hi Tig
          I found the other folders and entered them , but when I open SU it says error in loading
          Any ideas?
            @deanlegg said:
            Hi Tig
            Any ideas?
            You need to do it one script at a time.
            Extract them into a temporary location and look at the folder structure.
            Check Plugins to see if files are NOT in the same locations - if so remove them.
            Now copy the files and files within their subfolders into Plugins.
            Restart and see if that one script works... πŸ˜•
