    A problem with the Entity Info box
    6 Posts 3 Posters 1.0k Views 3 Watching
    • W Offline
      watkins
      Dear All,
      I am experiencing problems when using the Entity Info dialogue box to rename groups and components.
      This is best illustrated with an example. Open up SU and draw two boxes. Make one a group, and then name it Box 1 using Entity Info. Make the other a component and name it Box 2. Go back to Box one, select it and then rename it Box 3, again using the Entity Info dialogue box. Now select Box 2 and try to change the DEFINITION NAME field to Box 4. I find that the text 'Box 3' appears in the NAME field, which is really annoying.
      Am I the only one experiencing this apparent 'bug'?
      Best wishes,
      Bob
        Interesting but true, works the same way for me.
        Maybe it is only a "courtesy" by the development to pre-fill the name field thinking that when you are in naming anyway, you may want to use similar names
        (Well, half joking...)
        • mitcorbM Offline
          mitcorb
          Sort of like autocomplete, or just recalling last named.
          • W Offline
            watkins
            Yes, but really annoying.
            It would be nice if one could use Outliner to both 'identify in model'and rename without having to use the Entity Info box. Outliner needs a lot of work before its full potential is realised.
            Regards,
            Bob
            • W Offline
              watkins
              Dear Gaieus,
              Can this thread be re-labelled as SU bug?
              Thanks,
              Bob
                Moved to the bugs subforum.
