    A problem with the Entity Info box
    6 Posts 3 Posters 1.2k Views 3 Watching
    • W
      watkins
      Dear All,
      I am experiencing problems when using the Entity Info dialogue box to rename groups and components.
      This is best illustrated with an example. Open up SU and draw two boxes. Make one a group, and then name it Box 1 using Entity Info. Make the other a component and name it Box 2. Go back to Box one, select it and then rename it Box 3, again using the Entity Info dialogue box. Now select Box 2 and try to change the DEFINITION NAME field to Box 4. I find that the text 'Box 3' appears in the NAME field, which is really annoying.
      Am I the only one experiencing this apparent 'bug'?
      Best wishes,
      Bob
      • GaieusG
        Interesting but true, works the same way for me.
        Maybe it is only a "courtesy" by the development to pre-fill the name field thinking that when you are in naming anyway, you may want to use similar names
        (Well, half joking...)
        • mitcorbM
          mitcorb
          Sort of like autocomplete, or just recalling last named.
          • W
            watkins
            Yes, but really annoying.
            It would be nice if one could use Outliner to both 'identify in model'and rename without having to use the Entity Info box. Outliner needs a lot of work before its full potential is realised.
            Regards,
            Bob
            • W
              watkins
              Dear Gaieus,
              Can this thread be re-labelled as SU bug?
              Thanks,
              Bob
              • GaieusG
                Moved to the bugs subforum.
