    Awning problem
    3 Posts 3 Posters 566 Views 3 Watching
      lmckay9898
      Im trying to build an awning that goes around the corner of the building at 90 degrees. There must be some way to pull the awning around the corner (maybe push-pull?) Im not sure.
      Help would be appreciated greatly!
        mac1
        push pull works normal to the surface so around corners is a problem. Use the follow me tool , think of a section through your awning ( so it will probably look like an L shape with top part of it slanted to account for the slope and the bottom the " eave". Draw this and have it follow a line you have drawn. The follow me needs a small surface to work on so you will have to add thickness to the material to get that ref.
        See this link http://www.youtube.com/results?search_query=sketchup+follow+me+tool&aq=0
        • Jean LemireJ Offline
          Jean Lemire
          Hi folks.
          See this SU file for ideas:
          Awning ideas.skp
