    Modeling timer
    5 Posts 4 Posters 571 Views 4 Watching
    • J
      Jakbaehl
      Does anyone know if there is a plugin for taking the time you have used on a model? I mean, how long did you use on any given model? Have searched, but i have not found anything so far.
      • J
        jaxcoffee
        Check with the invoicing program called Freshbooks. They have an add on program for timing work on your computer.
        • D
          d12dozr
          Have you seen this? http://www.smustard.com/script/TimeTrack
          http://goo.gl/f7ooYh
            I use TimeTrack and it works very well. I have keyboard shortcuts set up to start and stop the timer which helps.
            • J
              Jakbaehl
              I think i will give the TimeTrack a go. Thanks ppl! πŸ‘
