    Modeling timer
    5 Posts 4 Posters 543 Views 4 Watching
      Jakbaehl
      Does anyone know if there is a plugin for taking the time you have used on a model? I mean, how long did you use on any given model? Have searched, but i have not found anything so far.
        jaxcoffee
        Check with the invoicing program called Freshbooks. They have an add on program for timing work on your computer.
          d12dozr
          Have you seen this? http://www.smustard.com/script/TimeTrack
          http://goo.gl/f7ooYh
            I use TimeTrack and it works very well. I have keyboard shortcuts set up to start and stop the timer which helps.
              Jakbaehl
              I think i will give the TimeTrack a go. Thanks ppl! πŸ‘
