    [Request] Distance from camera to object.
    12 Posts 4 Posters 4.2k Views 4 Watching
    • jason_marantoJ
      jason_maranto
      I'm searching now but if anybody knows if such a tool exists that would be very helpful.
      Best,
      Jason.
      • jason_marantoJ
        jason_maranto
        Ok, I just read through 32 pages of search results and I don't see what I need so I guess this is a request:
        I would like a tool that allows the user to get feedback (a "heads-up" display like this plugin: http://forums.sketchucation.com/viewtopic.php?p=232984#p232984 would be extra cool) as to the distance from the current camera location to any selected object... Ideally I need to get the distance to set up near and far planes for Z-Clip and Z-Buffer.
        Best,
        Jason.
        • mitcorbM
          mitcorb
          I thought either Jim Foltz or TIG had done something along these lines?
          • jason_marantoJ
            jason_maranto
            That would be cool -- I'll keep looking.
            Best,
            Jason.
            • jason_marantoJ
              jason_maranto
              I checked TIG's plugins and I don't see anything there -- I'll checks Jim's in a bit.
              Best,
              Jason.
              • jason_marantoJ
                jason_maranto
                Nope, I don't see anything By Jim either... I think I must have stumbled upon a true request.
                Best,
                Jason.
                • honoluludesktopH
                  honoluludesktop
                  This is not difficult to calculate as long as you know the angle of view, and its corresponding dimension of the object. Problem is knowing the dimension of the object you wish to measure the distance to.
                  • honoluludesktopH
                    honoluludesktop
                    Perhaps the height and width of the object can be approximated by its nominal bounding box, then along with the fov, the distance to that object calculated. Problem with this is if the bonding box is at a angle to the camera. Maybe someone can come up with a more workable method.
                    • jason_marantoJ
                      jason_maranto
                      Thanks for the response -- Alternately some sort of near and far plane preview mode where the planes are adjustable would work if that was easier than trying to do it the other way... I'm all about making it as easy as possible 😄
                      Best,
                      Jason.
                      • jason_marantoJ
                        jason_maranto
                        Cool, Thank-you Didier 😄
                        Best,
                        Jason.
                        • Didier BurD
                          Didier Bur
                          This is a (very) rough rework of Thomthom's view direction.
                          It display the camera position (in.), the target location (in.) and the distance between the two, via a raycast.
                          Targeted object is temporarily selected.
                          Hope this is useful,
                          Drop it in the Plugins folder, usage: View menu > Camera->Oject Distance
                          hud_dist2obj.zip
                          DB
                          • jason_marantoJ
                            jason_maranto
                            Hey I didn't see you edit this to include the plugin -- very cool! Thank-you
                            Best,
                            Jason.
