๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
[Request] Distance from camera to object.
12 Posts 4 Posters 3.7k Views
    jason_maranto
    I'm searching now but if anybody knows if such a tool exists that would be very helpful.
    Best,
    Jason.
      jason_maranto
      Ok, I just read through 32 pages of search results and I don't see what I need so I guess this is a request:
      I would like a tool that allows the user to get feedback (a "heads-up" display like this plugin: http://forums.sketchucation.com/viewtopic.php?p=232984#p232984 would be extra cool) as to the distance from the current camera location to any selected object... Ideally I need to get the distance to set up near and far planes for Z-Clip and Z-Buffer.
      Best,
      Jason.
        mitcorb
        I thought either Jim Foltz or TIG had done something along these lines?
          jason_maranto
          That would be cool -- I'll keep looking.
          Best,
          Jason.
            jason_maranto
            I checked TIG's plugins and I don't see anything there -- I'll checks Jim's in a bit.
            Best,
            Jason.
              jason_maranto
              Nope, I don't see anything By Jim either... I think I must have stumbled upon a true request.
              Best,
              Jason.
              • H Offline
                honoluludesktop
                This is not difficult to calculate as long as you know the angle of view, and its corresponding dimension of the object. Problem is knowing the dimension of the object you wish to measure the distance to.
                • H Offline
                  honoluludesktop
                  Perhaps the height and width of the object can be approximated by its nominal bounding box, then along with the fov, the distance to that object calculated. Problem with this is if the bonding box is at a angle to the camera. Maybe someone can come up with a more workable method.
                    jason_maranto
                    Thanks for the response -- Alternately some sort of near and far plane preview mode where the planes are adjustable would work if that was easier than trying to do it the other way... I'm all about making it as easy as possible ๐Ÿ˜„
                    Best,
                    Jason.
                      jason_maranto
                      Cool, Thank-you Didier ๐Ÿ˜„
                      Best,
                      Jason.
                        Didier Bur
                        This is a (very) rough rework of Thomthom's view direction.
                        It display the camera position (in.), the target location (in.) and the distance between the two, via a raycast.
                        Targeted object is temporarily selected.
                        Hope this is useful,
                        Drop it in the Plugins folder, usage: View menu > Camera->Oject Distance
                        hud_dist2obj.zip
                        DB
                          jason_maranto
                          Hey I didn't see you edit this to include the plugin -- very cool! Thank-you
                          Best,
                          Jason.
