    [Request] Distance from camera to object.
    12 Posts 4 Posters 4.2k Views 4 Watching
    • mitcorbM
      mitcorb
      I thought either Jim Foltz or TIG had done something along these lines?
      • jason_marantoJ
        jason_maranto
        That would be cool -- I'll keep looking.
        Best,
        Jason.
        • jason_marantoJ
          jason_maranto
          I checked TIG's plugins and I don't see anything there -- I'll checks Jim's in a bit.
          Best,
          Jason.
          • jason_marantoJ
            jason_maranto
            Nope, I don't see anything By Jim either... I think I must have stumbled upon a true request.
            Best,
            Jason.
            • honoluludesktopH
              honoluludesktop
              This is not difficult to calculate as long as you know the angle of view, and its corresponding dimension of the object. Problem is knowing the dimension of the object you wish to measure the distance to.
              • honoluludesktopH
                honoluludesktop
                Perhaps the height and width of the object can be approximated by its nominal bounding box, then along with the fov, the distance to that object calculated. Problem with this is if the bonding box is at a angle to the camera. Maybe someone can come up with a more workable method.
                • jason_marantoJ
                  jason_maranto
                  Thanks for the response -- Alternately some sort of near and far plane preview mode where the planes are adjustable would work if that was easier than trying to do it the other way... I'm all about making it as easy as possible 😄
                  Best,
                  Jason.
                  • jason_marantoJ
                    jason_maranto
                    Cool, Thank-you Didier 😄
                    Best,
                    Jason.
                    • Didier BurD
                      Didier Bur
                      This is a (very) rough rework of Thomthom's view direction.
                      It display the camera position (in.), the target location (in.) and the distance between the two, via a raycast.
                      Targeted object is temporarily selected.
                      Hope this is useful,
                      Drop it in the Plugins folder, usage: View menu > Camera->Oject Distance
                      hud_dist2obj.zip
                      DB
                      • jason_marantoJ
                        jason_maranto
                        Hey I didn't see you edit this to include the plugin -- very cool! Thank-you
                        Best,
                        Jason.
