    KMZ Images
    4 Posts 2 Posters 374 Views 2 Watching
    • alexschreyerA Offline
      alexschreyer Extension Creator
      I got a lot of KMZ files (exported from SketchUp) that are very large (the people that made them didn't care too much about texture size).
      Of course this is mainly a texture problem. Has anyone figured out a quick way to resize textures in multiple KMZ files?
      The following procedure works well, but it needs to be scripted somehow:
      • Open folder containing KMZ files
      • Rename files as ZIP folders
      • Open all folders and resize containing images to max size (e.g. 800 px max width) and re-save with low compression
      • Rename all folders as KMZ files
      Has anyone figured out an automated way to do this? I am thinking Automator scripts would work well. I think I could also write a Ruby script for this. This could also be implemented easily as a web app. I just wanted to check what's out there before I embark on it.
      Cheers,
      Alex
      Author of "Architectural Design with SketchUp":
      http://sketchupfordesign.com/
        Seems prog like Irfanview, Fastone...make that very easily in one pass πŸ˜‰ (rename, resize or reformat etc)
        And it's free β˜€
          Do they work with ZIP files, too? That's what the KMZ is, after all. I can do the resizing of all images in a folder in Photoshop, too, but I want to make the ZIP decompress / compress steps automatic, too.
          Cheers,
          Alex
            For unzip some files in the same time use this πŸ˜‰
            But normaly CTRL + a --> Extract here in a folder must extract all zipped files in one pass !
            With WinRar there is no problem!
            But if some files have same names better extract in separated folder (asked by WinRar) πŸ˜„
