    Plz help - fixing IES file? - can't remember where or how
    extensions
    6 Posts 4 Posters 1.7k Views 4 Watching
    • shuraS
      shura
      Hi folks,
      Not very long ago I read a post from someone who didn't get his IES data to work. Sadly I don't even remember which renderer he used.
      He solved the problem himself by editing the IES file.
      Obviously I am in the same need now, but I can't for the life of me remember where I read it.
      So far I searched SCF (also Vray sub), Twilight and Thea Forum until I got a bit dizzy.
      Maybe someone has a better memory than mine, or even knows how to find mistakes in IES codes...
      ...thanks in advance
      alex
      • H
        harnstein
        Hm, I can't really help, but wouldn't it be a solution
        to re-create the ies with eg. "free ies creator"?
        still sketchin'
        • shuraS
          shura
          Thanks for the reply Sir,
          i thought of that too, but I did not dare to take that road yet, because I have like a hundred light fixtures to mount.
          Just now I thought it could be possible to find the error by reproducing only a few... Ill have to look into that.
          btw, the files from IESgenerator do mot render in Twilight, but General Electrics has a good free application that works for me.
          thanks again
          a.
          • FletchF
            Fletch
            Alex,
            Try this.
            http://www.photometricviewer.com/
            meanwhile, I will try the other IES creation program to see what your issue might be.
            Don't forget - if you post any issue on Twilight's forum, they are VERY responsive and helpful. πŸ˜‰
            Fletch
            3D Modeling addict. Former owner/developer of Twilight Render. sleepinggiantvisual.com
            • N
              notareal
              Perhaps you can post a sample of those IESgenerator IES files that wont work?
              • shuraS
                shura
                Thank you guys, good to have you alongside. It is just that with all text codes/scripts I'm a total noob.
                I am trying to use the IES files provided by Martin Lighting at http://www.martin.com/productgroup/productgroup.asp?pg=martinlight
                What is clear now is that the IES data is simply incomplete. The entire values for candela distribution is on zero.
                Looks like I have to send a request to Martin directly.
                Althoug I got one file from the architectural fixures to work, none of the headmoving fixtures seem to work...
                .....get back later, have an appointment
                cu
