    No zoom extents (despirate)
    7 Posts 4 Posters 499 Views 4 Watching
      steved
      Hi I have been working on a project for a while and i could not see much in the Newport so i zoomed out (a lot)so now i scroll around and zoom I can't see anything, no horizon, no axis lines. Tried zoom extents the zoom extents button will not activate IE: when i hit any other button it highlights, but not the zoom extent button. It highlights momentarily when i click on it but....nothing. In desperate need of help, must deliver project Tomorrow
      Thanks In advance
      Steve
      "If I agreed with you on that, then we would both be wrong"
        Hi Steve,
        Would the (default) shortcut key, Shift+Z work?
        What if after zooming to extent, you select all (Ctrl+A) to see if there is some small, stray geometry far-far away and therefore when you zoom extent, everything seems to "disappear" (because this has to be included as well)? Is there any CAD import in your file?
          steved
          HI Geaius, tried Shift +z no good and the rest of the suggestions to no avail. A DWG was not involved in this project.
          I have attached the su file to see if someone can "unlock it" any assistance would be greatly appreciated.
          Steve
          Cotages 21.zip
            dedmin
            Cotages 21.zip
              steved
              Dedmin, thank you! thank you! mate, do you mind if I ask how you did that. You actually went back till about 5 mins before the issue occurred!
              Genius
              Thanks again
              SD
                dedmin
                First i did some cleanup - Window > Model Info > Statistics > Fix Problems
                Found some errors and bad geometry, changed Field of View , played with the zoom and layers - On or Off
                The problem is - You are to far away from the origin.
                  Steve, when I opened your SKP file, I got exactly what you see below. I just opened the file and made a screen shot. I agree with Dedmin that your model should be closer to the origin.
                  FWIW, you will probably want to fix the reversed faces. They show as blue in your model.
