    Get Group Owner
    6 Posts 5 Posters 549 Views 5 Watching
      tictactoe
      The following Code makes groups in groups.
      width = 200
      depth = 100
      pts = []
      pts[0] = [0, 0, 0]
      pts[1] = [width, 0, 0]
      pts[2] = [width, depth, 0]
      pts[3] = [0, depth, 0]
      model = Sketchup.active_model
      g1 = model.entities.add_group
      g1.entities.add_face pts
      g1.transformation = Geom;;Transformation.new([10,0,10])
      g2 = g1.entities.add_group
      g2.entities.add_face pts
      g2.transformation = Geom;;Transformation.new([20,0,20])
      g3 = g2.entities.add_group
      g3.entities.add_face pts
      g3.transformation = Geom;;Transformation.new([30,0,30])
      puts "model; " + model.entityID.to_s
      puts "g1; " + g1.entityID.to_s
      puts "g2; " + g2.entityID.to_s
      puts "g3; " + g3.entityID.to_s
      puts "g3.parent; " + g3.parent.entityID.to_s + ", " + g3.parent.class.name
      puts "g3.parent.parent; " + g3.parent.parent.entityID.to_s + ", "
            + g3.parent.parent.class.name
      puts "g3.parent.parent.parent; "
            + g3.parent.parent.parent.entityID.to_s + ", "
            + g3.parent.parent.parent.class.name
      And results in
      model; Model
      g1; 25
      g2; 49
      g3; 73
      g3.parent; 40, Sketchup;;ComponentDefinition
      g3.parent.parent; 3, Sketchup;;DefinitionList
      g3.parent.parent.parent; Model, Sketchup;;Model
      Now question:
      Given g3, how can I get the owning/creating group g2 by code? g3.parent is not the right way.
        You can't traverse backwards like that.
        Given an instance, that instance can appear many places in the model, if any of it's parent nodes have multiple instance. That makes it impossible to get a path from instance > model. The other way works, model > instance - when you traverse the model tree.
        • K Offline
          kwalkerman
          ... You can get some information regarding inheritance in one of two ways:
          1. If the user is actively editing a group or component, you can get the current path using: Sketchup.active_model.active_path
          2. If you are traversing through the model's entities, you can keep track of where you are in the model and develop your own inheritance structure that way.
            Cleverbeans
            I believe g3.parent.instances[0] gives you the correct group.
              I repeat this from somewhere else...
              <span class="syntaxdefault"></span><span class="syntaxkeyword">class&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxcomment">###&nbsp;Sometimes&nbsp;the&nbsp;group.entities.parent&nbsp;refer&nbsp;to&nbsp;the&nbsp;wrong&nbsp;definition.&nbsp;<br />&nbsp;&nbsp;&nbsp;&nbsp;###&nbsp;method&nbsp;checks&nbsp;for&nbsp;this&nbsp;and&nbsp;locates&nbsp;the&nbsp;correct&nbsp;parent&nbsp;definition.<br />&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">not&nbsp;Sketchup</span><span class="syntaxkeyword">;;</span><span class="syntaxdefault">Group</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">method_defined</span><span class="syntaxkeyword">?(;</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">def&nbsp;definition</span><span class="syntaxkeyword">()<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;if&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">parent</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instances</span><span class="syntaxkeyword">.include?(</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">parent<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">else<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">Sketchup</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">active_model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">each&nbsp;</span><span class="syntaxkeyword">{&nbsp;|</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">|<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;return&nbsp;</span><span class="syntaxdefault">definition&nbsp;</span><span class="syntaxkeyword">if&nbsp;</span><span class="syntaxdefault">definition</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">instances</span><span class="syntaxkeyword">.include?(</span><span class="syntaxdefault">self</span><span class="syntaxkeyword">)<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;}<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxkeyword">return&nbsp;</span><span class="syntaxdefault">nil&nbsp;</span><span class="syntaxcomment">###&nbsp;Should&nbsp;not&nbsp;happen.<br />&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;</span><span class="syntaxdefault">end<br />&nbsp;&nbsp;&nbsp;&nbsp;end</span><span class="syntaxcomment">#if<br /></span><span class="syntaxdefault">end</span><span class="syntaxcomment">#class&nbsp;Group&nbsp;</span><span class="syntaxdefault"></span>
              Usage: defn = group.definition
                Not if the group has instances, which it may have after copying a group and not editing it.
