    Push 3D Text Into a Face?
    13 Posts 4 Posters 3.7k Views 4 Watching
    • V Offline
      VikR
      It's easy to get extruded 3D Text using SU's 3D Text tool. Is it possible to push the text into a face so that instead of being extruded, it is "intruded"?
      Thanks in advance to all for any info.
        You can intersect the face with the 3D Text and "merge" the text into the face. Have you got an example at hand?
        • soloS Offline
          solo
          Pretty easy, use SU8 solid tools, the subtract tool.
          http://img404.imageshack.us/img404/4242/capture48.gif
          http://www.solos-art.com
            That's Pro only, Pete. What if (s)he doesn't have the Pro?
            • soloS Offline
              solo
              Intersect and manually remove as we did before these automated tools, or get Booltools.
              This feels like a Simpsons episode.
                With your new spectacles?
                πŸ˜„
                • V Offline
                  VikR
                  Great! I just got Booltools. I'm having trouble moving my text along the green axis. I've read that if I push the left arrow that should enable me to move it on the green axis, but it doesn't seem to work. I've tried it like this:
                  • Create a cube
                  • Create 3D text and place it on the face of the cube
                  • Select 3D text with arrow tool
                  • Switch to move tool
                  • Hold down left arrow
                  • Click anywhere (I think I've tried every option) and drag in the direction my green axis is lined up
                  • But the 3D text keeps moving along the red axis, across the face of the cube
                  What is the correct way to do this? I'm using SU 8 free version on Mac OS.
                    d12dozr
                    Right click -> Unglue...then try moving it
                    http://goo.gl/f7ooYh
                    • V Offline
                      VikR
                      That worked. I now have the 3D text positioned correctly inside the face of the object. When I use BoolTools, I get a message saying that the 3D text is "not a valid solid." How can I correct this?
                        d12dozr
                        This video explains 'solid geometry'...the video is instructing for the Solid tools in SU Pro, but is applicable to BoolTools as well
                        YouTube - Google SketchUp 8: Solid Tools
                        [flash=640,390:2aavtfbk]http://www.youtube.com/v/TAS1EVOvDMo?fs=1&hl=en_US[/flash:2aavtfbk]
                        • V Offline
                          VikR
                          That explained it. I had two letters overlapping. I put a space between them and now SU recognizes the 3D text as being solid.
                          I've tried all 3 Booltools tools - selecting the tool; selecting the 3D text; then selecting the cube - but in all 3 cases either the text or the cube disappears. What am I missing? A test file is attached.
                          intruded text test.skp
                            d12dozr
                            Have you seen this? The order you choose the groups matters...I don't have BoolTools so I don't know specifics
                            YouTube - BoolTools for SketchUp Demo
                            [flash=480,385:1qpir2ck]http://www.youtube.com/v/umcoC1JQAFQ?fs=1&hl=en_US[/flash:1qpir2ck]
                            • V Offline
                              VikR
                              I think I'm following the video correctly, but I'm not getting the correct result yet. I've posted the question on the forum maintained by the makers of Booltools.
