    Push 3D Text Into a Face?
    13 Posts 4 Posters 3.6k Views 4 Watching
      That's Pro only, Pete. What if (s)he doesn't have the Pro?
      • soloS Offline
        Intersect and manually remove as we did before these automated tools, or get Booltools.
        This feels like a Simpsons episode.
          With your new spectacles?
          πŸ˜„
          • V Offline
            VikR
            Great! I just got Booltools. I'm having trouble moving my text along the green axis. I've read that if I push the left arrow that should enable me to move it on the green axis, but it doesn't seem to work. I've tried it like this:
            • Create a cube
            • Create 3D text and place it on the face of the cube
            • Select 3D text with arrow tool
            • Switch to move tool
            • Hold down left arrow
            • Click anywhere (I think I've tried every option) and drag in the direction my green axis is lined up
            • But the 3D text keeps moving along the red axis, across the face of the cube
            What is the correct way to do this? I'm using SU 8 free version on Mac OS.
              d12dozr
              Right click -> Unglue...then try moving it
              http://goo.gl/f7ooYh
              • V Offline
                VikR
                That worked. I now have the 3D text positioned correctly inside the face of the object. When I use BoolTools, I get a message saying that the 3D text is "not a valid solid." How can I correct this?
                  d12dozr
                  This video explains 'solid geometry'...the video is instructing for the Solid tools in SU Pro, but is applicable to BoolTools as well
                  YouTube - Google SketchUp 8: Solid Tools
                  [flash=640,390:2aavtfbk]http://www.youtube.com/v/TAS1EVOvDMo?fs=1&hl=en_US[/flash:2aavtfbk]
                  • V Offline
                    VikR
                    That explained it. I had two letters overlapping. I put a space between them and now SU recognizes the 3D text as being solid.
                    I've tried all 3 Booltools tools - selecting the tool; selecting the 3D text; then selecting the cube - but in all 3 cases either the text or the cube disappears. What am I missing? A test file is attached.
                    intruded text test.skp
                      d12dozr
                      Have you seen this? The order you choose the groups matters...I don't have BoolTools so I don't know specifics
                      YouTube - BoolTools for SketchUp Demo
                      [flash=480,385:1qpir2ck]http://www.youtube.com/v/umcoC1JQAFQ?fs=1&hl=en_US[/flash:1qpir2ck]
                      • V Offline
                        VikR
                        I think I'm following the video correctly, but I'm not getting the correct result yet. I've posted the question on the forum maintained by the makers of Booltools.
