    Problem transfering TOOLBARS ruby from V6 to V8
    4 Posts 2 Posters 394 Views 2 Watching
    • jgbJ Offline
      jgb
      I just bit the bullet and loaded SU-V8 Free. Spent the whole day (not quite done yet) making V8 behave like I am used to on V6. So for the best part of today I was "bringing over" my essential Plugins from V6 to V8. I was doing them 1 or 2 at a time and testing, and most went without a hitch. Where the plugin source was a zip I copied over the zip and unzipped it, while simple .RB's were just copied over.
      However the "TOOLBARS" ruby refuses to load in V8.
      Filename is Toolbars_08-06-01.zip.
      In V6 it presents itself in View/Toolbars/Options. It is not there in V8 (or anywhere) and there is no load error message. The main plugin file is Toolbars.rb which reads as follows
      *require "sketchup"
      require "extensions"
      path = File.join(File.dirname(FILE), "toolbars", "files", "loader.rb")
      ext = SketchupExtension.new("Custom Toolbars", path)
      ext.description = "Loads your custom Toolbars."
      ext.creator = "Jim Foltz jim.foltz@gmail.com"
      ext.copyright = "2008 Jim Foltz"
      ext.version = "2008-04-04"
      Sketchup.register_extension ext*
      Line 2 says it needs "extensions" but that file is not present in V6 anywhere I can see.
      So if that is a missing file, why does it work in V6 without it?
      It has several crucial tools I use consistently and they are a real pain to have to hunt them down in menus, especially the toggles.
      Any ideas??? ❓
      jgb
        Extensions are part of SU 6 and SU8. It' just that the files are under the Tools folder. No need to copy these. (And I'd recommend not.)
        Have you looked under Window > Preferences > Extensions and ensured the plugins are enabled?
          Also, have you checked for updates to the plugins?
          • jgbJ Offline
            jgb
            THAT was the culprit 😍
            Many thanks. Never thought of looking there.
            jgb
