    Update problems
    6 Posts 3 Posters 1.4k Views 3 Watching
    • kenK Offline
      ken
      Now after updating some plugins, I have the following files in the plugin directory.
      delauney2.rb and delauney3.rb. Should I have both or just one version? What happen to delauney.rb?
      Also have the following error when opening Sketchup after updating various plugin.
      Ken
      • mitcorbM Offline
        mitcorb
        This doesn't have anything to do with the Delaunay/ Delauney dichotomy, does it?
        • kenK Offline
          ken
          Ken
          Well, I am bring this to the front again.
            Ken
            That's my tool - please get the latest SKMtools downloaded and report back - there was a brief glitch on material.delete but it's fixed now [?]
            There hasn't been a delauney.rb needed for some long time.
            The delauney2.rb is used by Didier's point_cloud_triangulate.rb... BUT both these scripts have a shortcoming in that their methods a 'bare' - Solo had a recent clash, where he had some other script was making a 'raw' 'triangulate()' method that clashed with these... SO I rewrote both of them as delauney3.rb and TIGpoint_cloud_triangulate.rb with the methods wrapped safely in a Class... the second requires the delauney3... I suggest that you only need one delauney and one points_cloud... - remove the other [mine is safer and groups the mesh etc too]
            • kenK Offline
              ken
              Well apparently it was my bad. When I loaded the correct and up-to-date SKMtools20110116a.zip, problem solved.
              However, it appears that delauney2.rb is required, as shown.
              TIG again thanks for the help.
              Ken
                Ken
                So it looks like some other tools still use delauney2.rb - this leaves them open to fail when another script uses a different 'triangulate()' method outside of a class or module!
                It pretty easy to rewrite it to use delauney3.rb methods instead... 😉
                Press the author[s]...
