    New Material Methods! (With bugs :( )
    25 Posts 7 Posters 4.7k Views 7 Watching
      http://code.google.com/apis/sketchup/docs/releases.html
      Expanded the Material Class
      New methods:
      Material.remove
      Material.name=
      Material.write_thumbnail
      NOTE: There's a type here: it's Materials.remove(material)
      Bug Alert! 😢
      Sketchup::Materials.remove
      When you erase a material with materials.remove the entities with the material doesn't revert back to default materials. The material disappear from the material list, but is still applied to materials in the model.
      When you use "Fix Problem" it will report lots of invalid materials and it will then remove the material from the front side, but leave the back side with the invalid material.
      Workaround (annoyingly this means traversing the entire model - so it's not the fastest.)
      <span class="syntaxdefault"><br />def self</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">save_remove_material</span><span class="syntaxkeyword">(</span><span class="syntaxdefault"> material</span><span class="syntaxkeyword">,</span><span class="syntaxdefault"> model </span><span class="syntaxkeyword">)<br /></span><span class="syntaxdefault">  for e in model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />    e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">respond_to</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> material<br />    e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">respond_to</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> material<br />  end<br />  for d in model</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">definitions<br />    next if d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">image</span><span class="syntaxkeyword">?<br /></span><span class="syntaxdefault">    for e in d</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">entities<br />      e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">respond_to</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">material </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> material<br />      e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">=</span><span class="syntaxdefault"> nil if e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">respond_to</span><span class="syntaxkeyword">?(</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">;</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">)</span><span class="syntaxdefault"> </span><span class="syntaxkeyword">&&</span><span class="syntaxdefault"> e</span><span class="syntaxkeyword">.</span><span class="syntaxdefault">back_material </span><span class="syntaxkeyword">==</span><span class="syntaxdefault"> material<br />    end<br />  end<br />end<br /></span>
      • Dan RathbunD Offline
        Dan Rathbun
        New methods:
        Material.remove
        Material.name=
        NOTE: There's a typo here: it's Materials.remove(material)
        You mean it's an instance method of the Materials collection.
        I'm not here much anymore.
        • PixeroP Offline
          Pixero
          That's a great addition. I have some ideas that would greatly benefit from this... 🤓
          • simon le bonS Offline
            simon le bon
            but no retro compatibility 😢
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/NewMaterialMethods.jpg
            *s
              Oh great, a typo in my typo notice. 😒 😳
              No. That's evolution for yah. With the changes and additions in SU8 there might be some plugins that will require SU8 as a minimum.
                Just hope that no one had extended Material.name= anywhere. 😕
                Dan: did you say there was a way to detect if a method had been overwritten?
                • TIGT Online
                  This is 'detected' in my additional class methods and the code only makes the new method if it doesn't already exist...
                  Amongst others there are material.name='newname', material.delete and material.save_thumbnail('filepath') that mimic these new methods in this v8 only... so they get made in earlier versions as needed - see http://forums.sketchucation.com/viewtopic.php?p=301258#p301258
                  So
                  class Sketchup;;Material
                    if not Sketchup;;Material.method_defined?(;name=)
                     def name=(new_name=nil)
                       ### etc code to rename material
                     end#def
                    end#if
                  end#class
                  etc etc
                    Dan Rathbun
                    SO TIG you may wish to update your extension then to alias the method names write_thumbnail() and remove() ??
                      But there is no knowing of which other plugins has done this. There's a number of them that extended Group, Image and Array. It would be interesting to make a script that could scan the base classes for modification and map them. To get a feel of how the general state of the SU Ruby environment.
                        Dan Rathbun
                        Dont say there is no way, just because you don't know how (..YET,) ... remember Ruby is cool! Ruby will find a way, or allow a way through it's immaculate dynamistic glory.
                        • TIGT Online
                          I could - trust Google not to copy my naming conventions!
                            Dan Rathbun
                            They could be following the conventions they have established already in the API .. although they didn't in this case (which really irks me to no end.. a quick check of the API methods index is all it takes.. before 'inventing' a new method..)
                            All the other thumbnail methods use " save_thumbnail()"
                            " write" was used for images, textures, and IO operations, such as defaults to plist or registry.
                            " remove()" was used when you 'dettached' an item from something else, but did not actually delete or dipose of it, as in an observer, or removing entity references from the selection set.
                            " delete()" was used when you actually wanted to dispose of something, such as deleting an attribute, dictionary, or a set.
                            So the question is.. did they follow their OWN conventions with these new methods??
                              And why would the delete method be part of Materials instead of Material ?
                                Dan Rathbun
                                Because self.kill is suicidal, socially unacceptable, and often religiously repugnant.
                                Seriously, an object does not often dispose of itself, especially when it's a member of a collection. The collection class has a method(s) to dispose of one (or more,) of it's members. Ie Array instance methods: .shift, .pop, .slice etc....
                                  entity.erase! ... 😒 😄
                                    Dan Rathbun
                                    (1) that's not a Ruby method.. it's a Google written method (that doesn't really follow convention.)
                                    (2) It uses the **!** ("in place",) suffix to denote the operation is immediate against the receiver... BUT it is actually just an alias for Sketchup::Entities#erase_entities(receiver)
                                    .. yes there are bound to be variances ... likely caused by human error.
                                      Cursed! Materials.remove is bugged! http://forums.sketchucation.com/viewtopic.php?f=180&t=34217&p=301158#p301158
                                      • TIGT Online
                                        So material.remove doesn't exist BUT is in the API docs ???
                                        Then materials.remove(material) exists but doesn't work as expected !!!
                                        What is going on ???
                                        At least my 'clunky' old material.delete works... and it reverts all objects that were using that material to have 'nil'! [but it does have to traverse all model.entities and definition.entities too to achieve it !]
                                          Yes - the docs where wrong.
                                          Yea. When using Materials.remove you still need to iterate the whole model, but at least one doesn't ahve to create temp groups and use purge.
                                          Too bad this method is bugged when it finally appeared.
                                          But material.name= seem to work fine. Which is very good as one doesn't need to clone a new variant of the material.
                                            jhauswirth
                                            It is working as intended. It would all make sense if you guys could see how the Ruby API is implemented in SU.
                                            The Ruby API is a very thin wrapper around our C++ code. So in this case we have a CMaterialManager class
                                            in SU and the Ruby Materials class wraps CMaterialManager. When you get Materials from the model you get the
                                            Ruby wrapper around CMaterialManager. CMaterialManager knows nothing about the model. Its just
                                            a std::vector<CMaterial*> CMaterialVec; and all Materials.remove does is call
                                            CMaterialManager.RemoveMaterial(CMaterial*), which just removes the given material from the CMaterialVec.
                                            What everyone is asking for is probably a new method in model called model.remove_material (you guys can start
                                            another thread on what it should be called). This new method would live in model because
                                            model owns Materials and the entities that are assigned the materials. So model has all the info
                                            needed to implement what you are asking for. Sorry for messing this up, I sneaked these new methods
                                            in right before release which didn't get properly reviewed by the beta group because there were no
                                            release notes made for the new methods.
                                            • 1 / 2
