    Finding Model in Orthographic View (with Vray Camera)
    renderpluginsextensions
    3 Posts 3 Posters 1.7k Views 3 Watching
    • B
      bellerox
      hi,
      I have to make some elevations of my model and tried to render them with Vray (at University)
      We have SU8 (not pro) installed and Vray.
      My Problem is : I can render a perspective view of my model an get a rendering of that wahat is on my screen but if i'm changing perspektive view to orthografic View (Parallele Projektion in German) and try to render it dont renders my Viewport ... and i can't ( I really try!) adjust my viewport that i can see my model in the rendering ...
      do you know a answer? I have tried everything i knew and everything google knew ....
      thank you!
      • andybotA
        andybot
        orthographic view only works when physical camera is turned off. Physical camera only supports perspective view. Search the asgvis forum for more information on how to set up elevation or plan views.
        • R
          rspierenburg
          If you keep it in perspective view but change the angle to very close to 0 say 1deg you might be able to trick Vray into rendering it with physical camera still.
