    Show/hide Dialogs acting up
    4 Posts 2 Posters 285 Views 2 Watching
      Charlie__V
      Hello all,
      Before I reinstall V8 and V7 I thought I would ask if anyone has experienced erratic behavior with the show/hide dialogs.
      I have shortcut F4 assigned for show/hide dialogs, and this has worked for both V8 and V7 for some time now.
      I started having trouble in V8 a couple weeks ago......some dialogs would be missing or oversized (stretch the width of the window)after toggling show hide (F4).
      Closing and re starting would sometimes briefly restore some but not all dialogs.
      So I opened V7 and all appeared normal for a short while and then the same occured in V7.
      So now both versions appear to be experiencing the same problems.
      Any Ideas?
      Best,
      Charlie
      • mitcorbM Offline
        mitcorb
        Would your system specs,OS or any of that be helpful here?
        EDIT: I am thinking someone that knows about this stuff would want to know 😄
          Charlie__V
          mitcorb,
          Thanks for your interest in my problem.
          OS is MS XP Pro.........I have fixed the issue by doing a repair/install instead of remove/reinstall (first time that ever worked!) ;~)
          Interesting note:
          Repairing the V8 also fixed the V7 issue........? 😲
          Best, and Thanks
          Charlie
          • mitcorbM Offline
            mitcorb
            Hi, Charlie:
            I am glad that you were able to overcome the issue. I can see it was definitely out of my ability. 😄
