    Pull up only one side of a face?
    2 Posts 2 Posters 938 Views 2 Watching
      Tamera
      Hello,
      Hoping someone can tell me how I can pull up only one side of a face. For example, how would you create an A-frame? I looked through the tutorials but couldn't find an answer. Thanks much for your input. Tamera
        Select only the edge that needs to move and use the Move tool to lift it up. So in the case of your A-frame and assuming you've drawn a simple box and added a line for the ridge. Select that ridge line and move it straight up.
