    Where to Store User Settings?
    29 Posts 7 Posters 3.6k Views 7 Watching
    • J
      Jim
      Here's an article with some more specific info for working with several recent versions of Windows.
      What’s the Recommended Location for Application Files?
      The article only confirms what has already been said here: %APPDATA% is the correct folder (or better to use your own sub-folder under %APPDATA%.)
      • thomthomT
        But roaming or local?
        • J
          Jim
          Why not always roaming? Is there a specific case for local?
          I might use local if the file(s) were for a license key tied to a specific machine. But otherwise, I can't think of a reason not to use roaming.
          • thomthomT
            Yea - I wasn't sure if roaming could be used if the user where not on a domain. (I don't have any experience with that kind of stuff...)
            • TIGT
              ENV["APPDATA"] returns the PC User's 'Roaming' folder anyway... 😕
              • K
                kirill2008
                I think it is possible to store user settings right in *.skp file. Why not? AutoCAD stores a lot of settings (a plenty of settings) in *.dwg file for example.
                I'm not sure about problems with such approach, but it works well for some of user settings. I use "Sketchup.active_model.set_attribute" to store user settings.
                Ok, it's not ideal solution of course: it increases file size, I guess. And it does not fit for user settings, that have to be insensitive for *.skp file. And a lot of excess data will be attached to each *.skp file instead of single *.ini file.
                • thomthomT
                  That would then not be User data - but Model data. Two very different things.
                  • TIGT
                    User data specific to Sketchup can be stored with Sketchup itself in the Registry [Plist on Mac] ?
                    Sketchup.write_default(section,variable{,optional_default}) Sketchup.read_default(section,variable,value)
                    You obviously need to 'compile' the value[s] to write and read back in specific ways.
                    If there are 'many things' to keep across sessions then a saving them into a Users/Name/AppData/Roaming/ Sketchup subfolder, inside a tool specific subfolder or ini file etc would also be possible - not sure about Mac alternative...
                    • K
                      kirill2008
                      Looks like I interpreted thread subject in a context of my own thoughts 😳
                      I mean, I was going to suggest to use template for storing user settings data.
                      It is less elegant than just click "OK" button in "Settings" dialog of the plugin, of course 😄 But the user can save his own presets in template file, add description to it, then it will be possible to revert back to any previously saved configuration.
                      UPD.
                      The point is that I was thinking about abstract "application user" not the operating system user. Application means plugin here.
                      So I thought that application (plugin) usually runs "system wide" (not in "per user mode") and the problem is what is the best way to persist application settings (i.e. user preferences *application user here again).
                      Storing plugin settings right in document allows user preferences persistence across different machines and even across operating systems in theory 😉 (when I say "user" I mean plugin user). So user can take his *.skp file anywhere and continue working with it on any device that has SU and plugin 😄 and he does not have to care about configuring plugin again on each device.
                      • 2 / 2
