    Moving points
    6 Posts 4 Posters 532 Views 4 Watching
      jwallis
      Hi Im returning to sketchup after not using for some time.
      One thing im not sure that i ever figureed out is how to move points around.
      I am doing some GE modeling. I trace a shape on the ground to push/pull. Though if i need to edit that shape before i push/pull how can i move individual points. It seems i can only move the whole shape or the contained lines not individual points/vertices.
      thanks
        Jim
        Hi Job,
        The Move tool will move vertices, but you need to deselect everything before moving a vertex.
        • mitcorbM Offline
          mitcorb
          I would add that you cannot "select" a vertex the way you would a face or edge. You simply activate the move tool and hover over the vertex until you see the green dot and left click.
            jwallis
            thanks Jim. That seems so simple i feel like a twit.
            I think i was trying to select the vertice first.
            thanks
              Don't feel like a twit. SU's preselect function is so obvious with all other entities that this exception should not be so evident.
                Jim
                I couldn't even find mention of it in the docs for the Move tool.
                http://sketchup.google.com/support/bin/answer.py?answer=94859
                Oops nevermind, it's right there, although it doesn't specifically mention moving points:
                http://sketchup.google.com/support/bin/answer.py?answer=94860
