    Row of components in the same distance?
    5 Posts 3 Posters 390 Views 3 Watching
    • jo-keJ Offline
      jo-ke
      I'm working quite a while with SU but there is one thing, that I didn't found out yet:
      If I want to make a row of components with the same distance, what is the trick to get always the same distance?
      http://www.zz7.de
        d12dozr
        Copy a component with Move+Crtl, then type *10 and Enter to make 10 copies.
        ...or you can type /10 to make the copies between the start and finish points.
        This also works with the Rotate tool.
        http://goo.gl/f7ooYh
          d12dozr
          Here, Aidan explains better than I can ๐Ÿ˜„
          YouTube - SketchUp: Moving and copying like a champ, Part I
          [flash=480,385:3aggpc12]http://www.youtube.com/v/M2xlYnXzOt8?fs=1&hl=en_US[/flash:3aggpc12]
          YouTube - SketchUp: Moving and copying like a champ, Part II
          [flash=480,385:3aggpc12]http://www.youtube.com/v/K93025DDUpw?fs=1&hl=en_US[/flash:3aggpc12]
          • simon le bonS Offline
            simon le bon
            Hi JO-KE
            You can also take advantage of this great ruby by Chris Fullmer:
            [Plugin] Component Stringer
            http://forums.sketchucation.com/download/file.php?id=37116&t=1
            MatrixProximity By TIG
            http://www.pushpullbar.com/forums/attachment.php?attachmentid=45605&stc=1&d=1224254266
            Compo_spray by Didier Bur
            [Plugin] Component Spray update
            http://www.pushpullbar.com/forums/attachment.php?attachmentid=54035&stc=1&d=1245214267
            Re: Thanks to PUSHPULLBAR for its Ruby's review ๐Ÿ˜‰
            ๐Ÿ˜‰ simonlebon
            • jo-keJ Offline
              jo-ke
              Oh thank you very much.
              Some things are very easy if you know how it works ๐Ÿ˜‰
              http://www.zz7.de
