    Garden WIP
    15 Posts 3 Posters 1.6k Views 3 Watching
    • F Offline
      FilipAGuy
      Hello guys. This is my last render where I was mostly testing new vegetation created by TOM. Model still need
      some more details like furniture, lighting system, etc. I will do some postprocesinf as well, but any advice
      is more than welcome πŸ˜‰ πŸ˜„
      And I must say huge thanks to TOM for his incredible work !!! πŸ˜„
      part of courtyard
      ASUS G73JH-A1 (ASUS G73JH-TZ002Z) i7-720 QM, RAM 8GB DDR3 1333 MHz, HDD 1TB (2x 500GB 7200 rpm), Blu-ray Combo, ATI Radeon HD 5870 1GB
      • Bryan KB Offline
        Ooooh. Very nice. Looks inviting.
        • F Offline
          FilipAGuy
          Thank you Ecofeco for kind words πŸ˜„ I tryed to render vegetation without shdw layer, but I cant see difference.
          • F Offline
            FilipAGuy
            Some new renders. Basicly same area just different angles.
            • Bryan KB Offline
              I wish that were my garden.
              • F Offline
                FilipAGuy
                Thank you ecofeco for nice words πŸ˜„
                I dont know why but still getting sometimes stripes in my renders and also trees dont face properly.
                • Bryan KB Offline
                  A day and an age. Very nice.
                    tomsdesk
                    @filipaguy said:
                    ...also trees dont face properly.
                    The tree in the background needs to be made "unique" so it will render properly. (Have you talked to the podium folks about the stripes?)
                    2.5D Trees & Shrubs!
                    • Bryan KB Offline
                      I found that "boosting" my video card, SketchUp and rendering looked far better.
                      By boosting, I mean using the video card control panel to get the highest quality possible from it.
                      For instance, I use ATI, and it has its own control panel called "Catalyst Control Center" where I have more control over the video card than the standard operating system controls.
                      Give that a try if you have something like that and see if it helps.
                      • F Offline
                        FilipAGuy
                        Thank you TOM. I know im problematic one 😞 I talked about stripes, but no solution yet. Its strange that stripes are random. I will make them unique.
                        • F Offline
                          FilipAGuy
                          Hey Bryan. I have ATIcard as well. But what you tuned in CCC ???
                          • Bryan KB Offline
                            Find the 3D controls and increase all the settings. Seelct "AA" "AAA" "AF" and "Ai" or just select "All."
                            • F Offline
                              FilipAGuy
                              Thank you Bryan so much for advice !!! πŸ˜‰
                              Here is last render. Still WIP.
                              I have one problem for ages. I want to make green wall, but even good textures are not enough.
                              So I was thinking about cutting some segments out of original texture make them PNGs and place them
                              in front of wall to make more realistic look. Problem is that I dont know how to make them casting
                              proper shadow. I hope you understand. I know that there is some alpha channel tehnic to do it but
                              i dont know how. Any advice or help. Thank you in advance.
                              • Bryan KB Offline
                                Did that help with your video card? The new renders look good.
                                • F Offline
                                  FilipAGuy
                                  Im not sure Bryan, but I guess so. And I think that is rendering faster. I dont know how
                                  graphic card work during rendering. I have 4 core cpu and its under 100% load, but graphic card
                                  is not working a lot. But I can see improvment clearly. Anyway thank you for help. I would like
                                  to know more about it. Have to do some searching πŸ˜„
