    [Plugin] Update Links Manager
    31 Posts 16 Posters 27.7k Views 16 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Here is an update of my very old script "Links manager". You can link URLs or files to any SU object, delete links, open links, display links. Pdf Doc included.
      What's new: toobar, cursors, tooltips, webdialogs.
      Also available on RLD.
      Regards,
      Please get the latest version from the PluginStore http://sketchucation.com/pluginstore?pln=Links_Manager
      Edit 27.12.10: fixed glitch (no dialog was shown).
      English version. Unzip in Plugins folder.Version française. Dezipper dans le dossier Plugins.
      DB
      • W Offline
        watkins
        Dear Didier,
        Thank you for the updated plugin. Would one use the plugin to reference downloaded models (shower units, furniture etc) to their origin/manufacturer?
        Have a good Christmas.
        Kind regards,
        Bob
          Ben Ritter
          Thank you Didier.
          • simon le bonS Offline
            simon le bon
            Thank you Didier,
            surely useful in many cases.
            best wishes for 2011
            *simon
            • F Offline
              fountainhead
              I've updated, but am having a problem viewing the dialog window... see below.
              http://img840.imageshack.us/img840/3912/printscreenw.jpg
                Didier Bur
                What does the console say ? I suppose it cannot find the html file to load it in the dialog.
                Please copy-paste-post the error message in the console.
                Try with the RBS file below, extract it and move it to the 'Links Manager' folder. Tell me if it works so I can release the patch.
                Regards,
                linkToolsPatch.zip
                DB
                • F Offline
                  fountainhead
                  Hi Didier,
                  Thanks for getting back to me.
                  I tried the updated .rbs file you sent, and got this:
                  Windows Internet Explorer error message: Cannot find 'file:///Links%20Manager/linkTools.html'.
                  The syntax is exactly as shown, including the triple backslash. When I close the error window, the Links Dialog Window opens, but it is completely blank now.
                  If I download and install the french version it works perfectly. I also tried using fr_sulinks.rb, with fr_linkTools.rbs in the Links Manager folder, but I left in the english version of linkTools.html. This also worked perfectly, with the exception that the Links Dialog Window was titled Liens instead of Links.
                  Since I am no code guy, I am of little help in determining the problem. I am unsure how to get the Ruby Console to report the error you requested that I copy and paste, but would be glad to comply with some instruction on how this is accomplished.
                  Thanks again.
                  • F Offline
                    fountainhead
                    I need to be a little clearer on one item...when I loaded the french version and everything worked great, I replaced the fr_linkTools.html file with the linkTools.html file from the english version, and simply renamed it from linkTools.html to fr_linkTools.html. As I mentioned before, this got me everything in English except the title of the dialog window, which remained 'Liens'.
                    Sorry if my previous explanation on using the linkTools.html was a bit confusing, or misleading.
                      Didier Bur
                      I think I see where the issue is.
                      Please wait for a correct patch...
                      DB
                      • GeorgeG Offline
                        George
                        Hello Didier,
                        Another user and I are experiencing the same problem with Links Manager as fountainhead describes.
                        Here’s the topic in the SU Help forum:
                        https://productforums.google.com/forum/#!category-topic/sketchup/sketchup-pro/tvCz8dHb5OY
                        I click on the Links Manager toolbar to launch the script.
                        Then, click on a Component to set URL.
                        IE8 then displays the message pictured below.
                        I tried this with SU’s Ruby Console open. The console remained blank.
                        The previous version "Links" works fine.
                        http://rld.crai.archi.fr/rld/plugin_details.php?id=229
                        Yours,
                        George
                        https://lh3.googleusercontent.com/-JXI3pdyhXFA/T70OCH4VuUI/AAAAAAAAFoM/olbc0biUQFM/s601/Links%2520Manager%2520Error.PNG
                        "Everyone is entitled to his own opinions, but not to his own facts." ~Patrick Moynihan
                          Didier Bur
                          Here is another version for Links Manager (english version) that should work. The scrambler does not his job properly IMHO...
                          Put this file in your Plugins/Links Manager folder, and delete the previous linkTools.rbs
                          DB
                          • GeorgeG Offline
                            George
                            Thank you Didier 😄
                            Success !
                            • goatboyG Offline
                              goatboy
                              Hmmm.
                              SU Pro V8.0.15158 - ASUS - Windows 7 - Core i7 - NVIDIA Geforce GTX - Chrome
                              I have spent the afternoon trying to get this to work in all the various forms (english and french). I get this over and over:
                              Message from 000_AdditionalPluginFolders
                              1 ERROR(S): The following plugins had errors and may not be fully loaded:
                              PLUGIN: sulinks.rb
                              Folder:/program files (x86)/Google/Google SketchUp 8/Plugins
                              ERROR: undefined method 'file_loaded?' for main:Object
                              Really, Really, want to do links in SU.
                              • goatboyG Offline
                                goatboy
                                TIG helped me with a corrupt SU8 install (my doing) and 'links' now works as advertised.
                                I think it will really help out with my project.
                                Thanks to all.
                                • goatboyG Offline
                                  goatboy
                                  Follow-up:
                                  With this ruby, I can attach a url to an object so that it is displayed (see attached image), but the viewer can't do anything with it (me, in this test).
                                  I am wanting the object to display a link to another file (which this does, but you can only copy it from the dialog box and then cut and paste in a browser).
                                  I am looking for the link tp be displayed and clickable active in the SU file...possible?
                                  What am I missing (aside from a brain!)?
                                  • GeorgeG Offline
                                    George
                                    @goatboy said:
                                    Follow-up:
                                    I am looking for the link tp be displayed and clickable active in the SU file... What am I missing ?
                                    When you activate the tool; note the message in the Status Bar at the bottom-left of the screen.
                                    Ctrl-Click to Open Links
                                    -Geo
                                    • goatboyG Offline
                                      goatboy
                                      OMG!
                                      THX!
                                      • goatboyG Offline
                                        goatboy
                                        An opportunity:
                                        Multiple links to same object.
                                        What I am trying to do: link several different types of information to the same object, like spec sheet, color selections, delivery schedules, maps, etc...
                                        I would like them to display in the pop-up that the current 'links' ruby provides and then give the user the choice of which to select.
                                        ArcView (GIS) and AutoCad have such functionality with their 'link' option, but I do not seem to be able to do the same with SU at this time.
                                        Any idea on what I can do?
                                        • Chris FullmerC Offline
                                          It would be fairly straightforward to do this as a plugin, you just need to find someone who needs a plugin to write. Maybe we should develop a plugin request list for authors looking for some fun challenges 😄
                                          All my Plugins I've written
                                          • N Offline
                                            nomeradona
                                            as someone in the field of education, this pluggin is very useful especially when you are using your sketchup model as educational tool. I loveeeeeeeeeeeeeeeeee it.. thank you ... 👍 👍 👍
                                            visit my blog: http://www.nomeradona.blogspot.com
                                            • 2 / 2
