    Sketchup navigation in modo
    5 Posts 4 Posters 1.2k Views 4 Watching
      drfabinex
      If there are any other Sketchup and modo users out there, here is the modo configuration file I have been working on.
      This CFG changes modo to have Sketchup-like navigation. Not a lot has been changed. Mostly I just changed the rotate/pan etc. to be based around MMB and modifiers, and changed any tools triggered by MMB that I could find to instead be triggered by alt-RMB. If they were set originally at ctrl-MMB I changed them to ctrl-alt-RMB, etc. you get the picture.
      Modo CFG's only save changes from the built-in default.
      Please let me know if it's useful, or if you find other commands that could be changed.
      This was made in the WINDOWS version of modo 501. Might work in other versions.
      You can open the file in a text editor to see the changes if you like.
      modo_sketchup.zip
        comatose
        Great idea. I will give it a try, thanks.
          Scostumatu
          sounds good. how do you load it into modo?
            drfabinex
            To load it into modo, go to the modo menu: FILE/IMPORT CONFIG
            Enjoy
            • P Offline
              pinoy
              How do you uninstall ? Sorry new to modo I try systems but can't find your config/
              plugin folder. Using 801 in mac it works but need to revert to default .
              Thanks for your help
