Resetting bounding box to match world axis
Typically, a component's bounding box (bb hereafter) is created parallel to the world axis. When the component is rotated, the bb rotates. When you explode the rotated component, explode it, then recreate the component, the bb is realigned with the world axis.
Is there a way to reset a component's bb to the world axis without exploding, then recreating the component? I tried:
%(#008000)["ComponentDefinition.invalidate_bounds
Invalidates the bounding box of your definition. This command forces the update of the bounding box of definition while inside an operation."]But, the bb did not reset parallel to the world axis. Any ideas?
The bounding box that is returned by SU is different than the one that is shown inside of sketchup when you select the component (if I recall correctly).
To get the visible bounds to change, you would need to edit the component definition, rotate all geometry inside the definition by the rotation of the instance's transformation (or perhaps the inverse of its transformation??). Then remove all rotation from the instance.
Something along those lines should do the trick,
Chris
I recall now, you helped me with this before:
comp.definition.entities.transform_entities(comp.transformation.invert!,comp.definition.entities.to_a)Didn't know that there might be a difference between bb, and what is shown.
You need to get the bounds of the definition - then transform that by the instance transformation.
That would reset scaling and translation as well.
If you get the bounds of an instance the bb will be oriented to the model or world axis.
The dashed line is the bbox.
The blue lines is the previous bbox?
[attachment=1:lqggpjwr]<!-- ia1 -->Temp00.png<!-- ia1 -->[/attachment:lqggpjwr]
[attachment=0:lqggpjwr]<!-- ia0 -->Temp01.png<!-- ia0 -->[/attachment:lqggpjwr]The dashed lines is the Boundingbox you get when you query the instance for it's boundingbox.
But the blue lines are the actual boundingbox, it's derived from the boundingbox of the definition transformed by the instance transformation. -
The dashed line is the bbox. It's always aligned to the world axis. The blue lines is the bbox when the component is created.
I changed the code from
bbox=e.boundstobbox=e.definition.bounds, and got this:
Nearly there. Take the points from the boundingbox's corners and transform them by the instance's transformation.
OK, before I go there, I aligned the bbox with the world axis and got this:
That's because the instance boundingbox will be oriented to the world axis. Whenever the instance is rotated of axis from this you will get a deviance.
I almost forgotten - I got a plugin that draws the selection boundingbox of instances: http://forums.sketchucation.com/viewtopic.php?f=323&t=29377
OK done. Where
clis a array of clines,entities.transform_entities(e.transformation,cl.to_a)transforms them into the bbox outline.
Thanks. -
Interesting topic,
This this knowledge end up in a plug-in? I'm looking for a way to reset the bounding boxes of 'rotate multiple' components
Register LoginAdvertisement
