    [Plugin] podium_texture+bumpmap script 20101211
    1 Posts 1 Posters 4.4k Views 1 Watching
    • TIGT
      See here for download http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
      TIG (c) 2010
      All Rights Reserved.
      THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR IMPLIED
      WARRANTIES,INCLUDING,WITHOUT LIMITATION,THE IMPLIED WARRANTIES OF
      MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
      podium_texture+bumpmap.rb
      Loaded by SKMtools.rb in the ../Plugins/ folder.
      Adds a new tool:
      podiumtexturebumpmap(materialname, folder, boolean)
      It requires other scripts - material.export_skm.rb plus
      material.save_bumpmap.rb, material.save_bumpmapinverted.rb
      and the associated .jar files for each of those scripts.
      To run type
      podiumtexturebumpmap("Brick66","C:\Temp\MyPodiumSKMs")
      It finds the Model's Material named "Brick 66" and saves a SKM of it to the
      specified folder [that must exist], with a bumpmap with the same name.
      If the 3rd argument ['boolean'] is given 'true' the bumpmap is 'inverted'.
      The SKM is name with a 'preffix' - 'PODIUM_Brick_66.skm' and the bumpmap as
      'PODIUM_Brick_66-bumpmap.png', the Material.texture IF any is also made
      named 'PODIUM_Brick_66.pjpg' [or .png as appropriate] - Note that this
      name might not match the texture.name inside the SKM itself at all...
      It returns a three element array:
      [path_to_material.skm, path_to_bumpmap.png, path_to_texture]
      The 2nd and 3rd elements might be nil if there is no texture associated
      with the material [the bumpmap is little use on a 'flat' material!]
      Donations:
      By Paypal.com to info @ revitrev.org PayPalButton
      Version:
      1.0 20101206 First issue
