    [Plugin][Code]SKMtools,Material/ImageTools
    176 Posts 36 Posters 268.3k Views 36 Watching
      http://forums.sketchucation.com/viewtopic.php?p=293677#p293677 Here is an updated version with the 'loader' script adjusted to avoid earlier loading scripts messing up the 'dir/load' paths...
      • BoxB Offline
        Perfect Tig, thanks, works now.
          Here's an update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
          It includes new methods:-
          Material.save_texture_and_thumbnail(folder)
          • saves Material's texture [if any] and its thumbnail [png] into a subfolder named after the material in 'folder' - returns that subfolder path or nil.
          SKM.save_texture_and_thumbnail(path_skm, folder)
          • saves SKM's texture [if any] and its thumbnail [png] to a subfolder named after the SKM in 'folder' - returns taht subfolder path or nil
          SKM.extract(path_skm, 'folder')
          • extracts all of the SKM's data into a 'hash': if the optional 'folder' is given the files from the SKM are extracted into a subfolder named after the SKM in 'folder'. All of the available SKM data is accessible from the 'hash', if 'folder' is given then the paths to the texture/thumbnail etc are accessible...
          ImageAnimator
          • new menu items 'Make_Unique' and 'Clone'.
          See individual tools threads for more details...
            Here's another update http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
            It contains a new tool ' gifxtractor' which lets you quickly extract PNG files for each frame in a given animated GIF file...
            • kenK Offline
              ken
              It appears that the version, ....3a.zip is missing two images for the last two menu items, make unique and clone.
              Thanks for all of your work.
              Ken
                Ken, the two new ' ImageAnimator' tools ' Make_Unique' and ' Clone' should only have appeared in the View > ImageAnimator sub-menu as they are not that often used - the toolbar buttons were a result of a typo in my code 😳
                This is the updated version ..13b...http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
                • X Offline
                  xrok1
                  WOW! 😲
                  good work πŸ‘
                  β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                  • erikBE Offline
                    erikB
                    tig,
                    fantastic ruby !
                    Only I can't seem to find the "make unique button"
                    In stead I see two times : set folder from selected images to Nil ?
                    greetings,
                    erikB
                      erikB
                      Another typo in my code πŸ˜’ the latest [corrected] version is here
                      This version also includes 'ImageTrimmer' - a tool to trim around transparent areas in a .png Image and make a new Component - useful to trim around 'cardboard' cutout people from photos etc... see here for more details http://forums.sketchucation.com/viewtopic.php?p=294815#p294815
                        The 'ImageTrimmer' now has an option to simplify the outline and a new separate tool to do this post processing too.
                          IMPORTANT NOTICE!
                          There has been a lone report of these tools not working - with a '.jar' file 'opening' rather than 'running'!
                          Many of these tools use small Java '.jar' executable files that do specific tasks like zip/unzip and image manipulation.
                          I have found that I can reproduce this weirdness IF I let a 'zip/unzip' application like AlZip or WinRar 'poach' the '.jar' file-type as one that it will open. If so then when Ruby tries to 'open' a '.jar' file instead of it 'executing' in Java [like it should], it 'opens' in the decompression application...
                          The solution = look at your WinRar etc settings and ensure '.jar' is NOT one of its file-types for opening... πŸ˜’
                            A stupid typo preventing ImageTrimmer working properly on MAC is now corrected. πŸ˜’
                              The time-out for ImageTrimmer file creation extended to 60secs to cater for larger files being slow to complete...
                                Some scripts have been recast to address glitches with MAC file paths.
                                Everyone should update to these new versions...
                                  ImageTrimmer time-out for larger .dat files extended, EdgeDetector.jar improved...
                                    Here's an update - some minor issues fixed... http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
                                      Here's another update - ImageTrimmer processing speed has been improved and 'hanging' is now much less likely... http://forums.sketchucation.com/viewtopic.php?p=293677#p293677
                                        Ben Ritter
                                        Thank you TIG
                                          The Image and Material class extended methods will now only load if not already defined by SUp itself [==future-proofing since there's no medium-term hope of them doing this themselves?].
                                            ImageTrimmer - glitches with simplify etc addressed and speed improved.
                                            • 8
                                            • 9
                                            • 2 / 9
