    Sketchup 8 + Windows 7 = plugins don't show up?
    7 Posts 5 Posters 1.5k Views 5 Watching
    • G Offline
      georglorenz
      I switched to a new computer and for whatever reason some of my plugins do not show up in the Plugins menu anymore. I am using Sketchup 8 pro and Windows 7. Did anyone ever have a similar experience?
      Could it be a Windows rights issue? I don't have admin rights on this machine but the plugins folder has been made accessible to me. Or am I missing something else completely?
      Please find one of my homemade plugins that have this issue below.
      Thank you much / g
      random flip
        mac1
        My guess you have not went to window, preferences, extensions and selected the boxes so they show ❓
        • G Offline
          georglorenz
          Thank you for the reply. Unfortunately they do not show up as extensions. In fact most of the missing plugins are as simple as the attached example. So as I put them in the Plugins folder and restarted Sketchup I expected them to appear in the Plugins Menu. But they don't.
          Is there a way to manually load a plugin from within Sketchup?
          thank you /g
          • KrisidiousK Offline
            Krisidious
            I think he means this is one of his own plugins... meaning he wrote it.
            from what I've heard with SU8 is that it is more strict on coding, perhaps you should go through and check for some small mistakes...
            By: Kristoff Rand
            • Didier BurD Offline
              Didier Bur
              @georglorenz: try the script I have attached and see if it works better.
              Regards
              gxl_randomflipc_modified.zip
              DB
                I run SU8 and Win7 - never had an issue due to Win7. Some plugins needed update for SU8, but that affected all OS.
                • G Offline
                  georglorenz
                  Regards
                  That worked! Thank you Didier!
                  Here is what I understand you did to the syntax:
                  model.start_operation "randomflipc"
                  changed to:
                  model.start_operation("randomflipc")
                  results = UI.inputbox prompts, defaults, "Random Scale Parameters"
                  changed to:
                  results = UI.inputbox(prompts, defaults, "Random Scale Parameters")
                  UI.menu("Plugins").add_item("gxl random flip"){gxl_randomflipc}
                  changed to:
                  UI.menu("Plugins").add_item("gxl random flip"){ gxl_randomflipc }
                  Is there a general guide or forum discussion for sketchup 8 syntax that would help me avoid these pitfalls in the future?
                  Thank you again /g
