[Plugin] Normal Map Maker
You need some surfaces visible from above which are NOT perpendicular to the camera view.
Yeah, what pbacot said is basically that all surfaces you have there have the same normal, therefore the same color and so you have a flat normal on the map.
You should slitghtly taper your shape into truncated piramidal shapes.
Ohh ok ! i got it !
Thank you so much Pbacot and JQL for the help !
