    SketchyPhysics3.2 (Dec 2)
    55 Posts 23 Posters 24.3k Views 23 Watching
    • robintR Offline
      robint
      This site seems to be moribund, not a lot happening?
      Anyway Ive solved the UI problem
      so all working ok now
      As one door closes another one slams in your face
      • robintR Offline
        robint
        here my 2c worth for sp 3.2
        if you want to make a reversible motor joint, use the hinge (as per sp2) and set the controller blue box to
        quote slider ( 'anyname' )
        you can see the same construction using the motor joint
        wish I didnt have to waste hours getting to this point.
        Also
        to make magnetic solids work you need to set the ui box status to magnetic
        and the magnetic force to a large value eg +- 1000
        not obvious is it?
        I wonder whether its worth contributing to a wikimanual at5 this stage if thereis going to be an sp4 completely recoded?
        Robin
          jblively
          I do believe that magnetic force is also affected by mass and scale. So if the model is very large, you'll need a larger value for magnetic force. If you have a small scale model, you can use a magnetic force of as little as 10 to see results.
          There is so much involved in SP, more documentation would be nice, but i'm just glad we have people here we can chat with who want to help!
            Does this vervion can works on the V6?
            • robintR Offline
              robint
              Hi JB
              good point
              afik though there is a density coeff, I dont know how well it correlates to the mass of an object?
              the apparent mass i governed by the size of the collision shape as set in the rt click physics setting
              havent figured this tiresome details out yet
              I have a number of cu4rious physical models i would like to post for discussion (eg double pendulums etc) but havent yet found a way to post these little experiments.
              It seems daft that one cant attach these on this forum - severly limiting
              Any ideas?
                CPhillips
                Yes magnets are effected by the size of an object.
                You can attach files to posts. Look at the bottom of the form and there is an "Upload Attachment" tab.
                • robintR Offline
                  robint
                  hi all
                  sorry pardon didnt see the tab for uploading
                  I was trying to make a chain rotating around 2 sprockets. The chain seems to want to fly apart, its all chaotic? even though its all supposed to be stationary, any ideas
                  btw i have su8 and sp3.2 dec2010
                  its all good fun but i wish i had more control over the way things work, bit hit and miss at the moment
                  btw although bugsplat is a good tool, i dont connect my main machine directly to the net for obvious security reasons, so cannot utilise bs directly. It would be much more convenient if bs made a composite text file stored conveniently which i could gather up and post here to help with su crashes. Its a bit cumbersome at the moment
                  cheers robin
                  a chain loop goes wrong
                    CPhillips
                    Please see here for an 'issue' with group.definition http://forums.sketchucation.com/viewtopic.php?p=300105#p300105 😉
                    • robintR Offline
                      robint
                      hi CP
                      thanx for the tip, will see if i can make it so.
                      any pointers on where to start on Ruby so i can at least know something of what im doing?
                      cheers
                      Robint
                      • robintR Offline
                        robint
                        @tig said:
                        CPhillips
                        I tried the code but it seemed to make things worse
                        Code: Select all
                        class Sketchup::Group
                        if not Sketchup::Group.method_defined?(:definition)
                        def definition() # make it so you can use group.definition
                        return(self.entities.parent)
                        end#if
                        something about a chain sp doesnt like
                        Im stuck, my chain flies apart
                        robin
                        attemtped chain
                        • robintR Offline
                          robint
                          High CP
                          I have used Poser 5 in the past and learnt about inverse kinematics and joints
                          I think there is a fundamental limitation that prevents you making a chain of joints because the last child joint has to join the first parent so the parent must then become a child. This would be inherently unstable (like positive feedback) which is why the joint flies apart in pieces
                          Can anyone confirm my guesswork or poiont me somewhere that a working chain has been made (ie will revolve around a sprocket
                          cheers robin
                          • H Offline
                            hpnisse
                            Hey, robint!
                            Your chain works perfect when you set the collision state correct in every single object 😄
                            Re. my chain 1.skp
                            ` /hpnisse`
                            ` Windows 7 U -Sketchup 8 -SketchyPhysics 3.2-Dec2 - from Sweden`
                            • OxerO Offline
                              Oxer
                              I have installed SketchyPhisics 3.2 on Mac with OSX 10.6.6 and SU8 and the plugin don't woks, SU read the plugin, appear the toolbars, you can create the shapes but when you press the play appears a window with this message:
                              Error initializing the Simulation: : uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/ControllerCommands.rb:777:in `initialize'
                              And in the ruby console this:
                              %(#FF0000)[String doesn't compile: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds#<NameError: uninitialized constant MSketchyPhysics3::SP3xSimulationContext::SPSounds>
                              /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in `new'
                              /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:727:in `initialize'
                              /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in `new'
                              /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1623:in `startphysics'
                              /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1650:in `physicsTogglePlay'
                              /Users/Oxer/Library/Application Support/Google SketchUp 8/SketchUp/Plugins/SketchyPhysics3/sketchyphysicstool.rb:1738]
                              I have reinstalled SketchyPhysics3.1 and works.
                              http://www.oxervision.blogspot.com/
                              • robintR Offline
                                robint
                                @hpnisse said:
                                Hey, robint!
                                [attachment=0:au7zhech]<!-- ia0 -->Re. my chain 1.skp<!-- ia0 -->[/attachment:au7zhech]
                                Hi H
                                Thanks for that tip, the model chain works for me now, but I dont understand how setting the object state to "show collision geometry" makes such a radicle difference?
                                obviously i dont understand this state? I looked on the tutor manual but that wasnt helpful
                                so i am puzzled
                                nice that one can actually make a set of revolving links
                                What we need now is a workable spring (with variable rate and damping). the legacy one only works in sp2.3 not in 3.2. perhaps its work in progress
                                can anyone tell me if joints have a built in friction?
                                A simple pendulum will slowly come to rest, so there must be some restraint or energy loss built in? is this variable?
                                in mechanical systems you need mass, stored energy (spring) and friction (damping) preferably using SI units so as to start physical modelling
                                BTW I was once involved with a brilliant guy who made an amazing music generating prog that allowed exploration of scales, rhythms etc. BUT he was a C++ script magician and his prog became a tangle compost heap of widgets with a poor and almost unusable manual. I tried to help sort out the mess but the guy simply couldnt organise his thoughts in a consistant and methodical manner so his brialliant concepts came to nought as prospective users lost enthusiasm and gave up.
                                If anyone is preparing to organise a proper manual for SP4 then I can offer my 2c worth
                                cheers
                                Robin
                                All good stuff as I had come to a brick wall till now
                                • robintR Offline
                                  robint
                                  hi all
                                  Im posting some models that illustrate some points and queries
                                  all comments gratefully received
                                  Robin
                                  [my cone n ball
                                  rotates using a motor hinge (when will this become reversible?
                                  Two balls used, small one falls to bottom so that larger one is off centre and crawls up the side and out otherwise just drops to bottom.
                                  nice demo of centripetal force and a hollow solid](/uploads/imported_attachments/elvl_myconeandball1.skp)
                                  [my lift ball
                                  tried using lift capsule and got it working, then i moved the capsule and it all fell apart. but now i cannot recreate a lift capsul with a slider or a piston
                                  strikes me that a slider is unnecessry as its the same as a piston but without accel and damping figures - so why bother.](/uploads/imported_attachments/E5tW_myliftball.skp)
                                  [my rotating box
                                  strange that the slider now makes a hinge behave like a servo
                                  If you push tha slider to one end then the cube over turns and starts rotating in an erratic manner (like a ball running up and down a valley then gaining enough momentum to over top and run down the next valley.
                                  before (maybe in a previous version of SP this feature would behave like a true reversible motor - now it doesnt? what happened
                                  also if you get it going full speed one way then throw it into full speed other way, it crashes SU](/uploads/imported_attachments/wXwb_myrotatingbox1.skp)
                                  [my spring box
                                  cant get the spring to move at all. is it now not supported in sp3.2 ?](/uploads/imported_attachments/IRVt_myspringbox1.skp)
                                    solodown
                                    Toujours pas de nouvelles pour faire fonctionner ce plug-in sous Mac OS X 10.5.8 avec Google SketchUp ?
                                    • Z Offline
                                      zunkian
                                      Hi!
                                      Is there a manual for SketchyPhysics for beginners?
                                      If there is one, please upload.
                                      Thank you.
                                      Andy
                                      • dereiD Offline
                                        derei
                                        Indeed a user manual for users that did not used ketchyPhysics before would be nice. I noticed that some beginners tips are to be fond here http://sketchyphysics.wikia.com/wiki/SketchyPhysicsWiki , but I'm sure that version 3.2 have much-much more features than are detailed there.
                                        Thanks.
                                        DESIGNER AND ARTIST DEREI.UK
                                        • 4 Offline
                                          4dHans
                                          Could you do like explosions in a future version? That would be cool! 😍
                                            mickeyao
                                            MBP with 10.5.8 Thanks!
                                            • 2 / 3
