    Motocross - CR 250 from first poly-up
    24 Posts 9 Posters 3.3k Views 9 Watching
    • Bryan KB Offline
      Yeow and wow!
      How are you making the more complex curved surfaces?
      • cheddaC Offline
        chedda
        The bike looks great nice job. Axeonalias how do you suggest adding decals without creating geometry i had this problem a while back. Intersecting geometry leads to other problems notably smoothing etc.
        Kraken Wrangler https://www.flickr.com/photos/132441293@N03/
        • pbacotP Offline
          great model ! πŸ‘ πŸ‘
          Please show wireframe detail or explain the poly decals πŸ‘ πŸ‘ πŸ‘
          • P Offline
            pixelmonkey380
            @bryan k said:
            Yeow and wow!
            lots of trial and error!
            I was having the same problem which is why i created the decal separately.
            I've never been able to get an image map to stay in the correct location, or have the color correct. It's just been easier to create the decal and have the clean edge and colors. Most of the decals, excluding the radiator shrouds, were made flat and then turned or laid to the next flat surface after being broken apart.
            The decals on the Radiator shrouds were made with a duplicate of the shroud, sliced, then re-colored. From that point, the position was moved 1/32" from the surface of the shroud and adjusted as needed.
            feel free to look around the models i've posted on the warehouse. Over the last year or so, i've gotten a much better grasp of the application.
            pixelmonkey380 models on the warehouse
            chris<pixelmonkey>:D
            • 2 / 2
