Solid groups problem
I'm having a problem with solid groups.
I have no problem with using the solid tools. But sometimes if i have a quite complex solid group, there could stay some "lost" edges inside, making it just a regular group, which can not be used with the solid tools. When i search inside the solid, most of the time i can find and delete the lost edge(s), making my regular group back into a solid group. But sometimes I just can't find it.Is there some plugin i can use for "purging" these lost edges inside a group ?
Or some other fast method ?
I've looked in the plugins-topic but couldn't really find which one i needed.Thanks
Thomthom's Solid Inspector should do the trick: http://forums.sketchucation.com/viewtopic.php?t=30504
Thanks!
Register LoginAdvertisement
