    [REQ] layer selection plugins
    6 Posts 5 Posters 794 Views 5 Watching
    • halroachH Offline
      halroach
      Hello!
      I'm looking for a plugin/set of plugins for layer handling - would be used primarily for autocad DWG imports- for quick cleanups without the need of autocad.
      1. "change to current layer" - select plugin - select geometry/component/group... => the layer the geometry is on is now the default layer
      2. "highlight current layer" - select plugin - select geometry/component/group... => the layer the geometry is on is highlighted (not set to be used)
      3. "layer isolate" - select plugin - select geometry => the layer the geometry is on is the only layer visible.
        all other layers are turned off.
      4. "layer un-isolate ...
      5. "turn off selected layer" - select plugin - select geometry => the layer the geometry is on is turned off.
      6. "layer search and highlight" - type a name of the layer in the layers window and as you type it narrows down the layers until you find the one you want to select - would work like the keyboard shortcuts dialogue.
      (I imagine that point 6 would be something that google would have to implement for changing the UI!?)
      suggestions and pointers are welcome.
      good day! ๐Ÿ˜Ž
      FlexTools - Super Quick Windows, Doors, Slats...
        dedmin
        Always use the "Search"
        http://forums.sketchucation.com/viewtopic.php?t=2275
          arjunmax09
          I want a plugin to that enables one to lock layers too ๐Ÿ˜’
          when you fail at something....you haven't really failed...you've found one way the thing will not work out
          • Didier BurD Offline
            Didier Bur
            So my Layer Manager is for you: http://rhin.crai.archi.fr/RubyLibraryDepot/plugin_details.php?id=217
            DB
            • wind-borneW Offline
              wind-borne
              @arjunmax09 said:
              it doesn't have lock layers option ๐Ÿ˜’
              โ“
              layer manager
              "To read between the lines was easier than to follow the text."OSX 10.11.6
              %(#BF80BF)[SU 8 pro
                arjunmax09
                ๐Ÿ’ญ
