    Curved Surfaces
    3 Posts 2 Posters 268 Views 2 Watching
      Jamien2010
      When trying to apply a material to a curved surface the material is all distorted is there a plugin that will allow you to make curves smoother instead of having to change the entity information after drawing each curve, thank you!
        Have you tried setting the material to Projected and applying it that way. Sometimes that works. Otherwise I think you'll need to use UV. ThomThom has a plugin that can help.
          Jamien2010
          Thanks for the information
