    Some SU8+ wishes... and as Christmas approaches, who knows?
    4 Posts 4 Posters 1.0k Views 4 Watching
    • dereiD
      derei
      I am sure that following suggestions had been raised before, but it's good to keep them fresh πŸ˜„
      -keyword filter for windows, like Outliner have: for Materials, Components ..and Layers could have too. In Components is that 3dWarehouse search, but why can't we search on local library?
      -details view for Materials, like Components have. Because hovering over each material to find its name it's not so accurate, often it have lags and it's slow process when you have 15-20 materials and some of them are too alike. And List view don't provide visual. And maybe in detailed view to see the size of texture tile?
      -Clear Ruby Console built-in function -it would be nice, right? β˜€
      I noticed that, when SU starts, first loads Getting Started toolbar, then unloads it and loads user's toolbars. What's the point to load something what's disabled? Just time and resource consuming.
      -fix that bug which causes the right-click menu to gray-out sometimes.
      -some way to be able to resize SketchUp window, without messing up all icons, Maybe a Lock Toolbar function Sometimes I need the sketchup window to be less than Full-Screen, and in this situations, if some icons would go out of screen would be OK, IF there would be a small (triangle) to access them in sort of vertical bar, like in MS Word, for example.
      -and, YES... ConstructionLine Stipple FIX ! πŸ˜„
      DESIGNER AND ARTIST DEREI.UK
      • thomthomT
        This has been caused by some plugins. Known causes are Fredo's plugins (update to latest version) and a very old version of Selection Toys.
        Might be others - but I'd not heard of any confirmed ones.
        • jbacusJ
          jbacus
          What's wrong with construction line stippling? I don't think this I've seen this one reported before.
          john
          "...exaggerate the essential and leave the obvious unclear." --Vincent Van Gogh
          John Bacus
          jbacus@sketchup.com
          • Chris FullmerC
            I believe that SU8 broke some stipple abilities with construction lines - at least that is what is reported here:
            http://forums.sketchucation.com/viewtopic.php?f=11&t=32730
            All my Plugins I've written
