    Box Tapering problem
    6 Posts 2 Posters 461 Views 2 Watching
    • hellnbakH Offline
      hellnbak
      I've use Fredo's box tapering before, and it's worked wonderfully (as do all of his amazing plugins). However, I'm having a problem now. I'm trying to taper an object, just move the face in a bit. Well, when I move the cursor in the direction I want, nothing happens, and then it snaps to .95. After that I can keep moving it in just as smoothly as you please, but I cannot get it to go anywhere between .95 and 1.00, if I try it just snaps back to 1.00. I've tried typing in the taper I want (somewhere around .98, although I can't be sure yet because I havent' been able to test it), but when I hit enter nothing happens. If I hit enter again it snaps back to 1.00. I've tried many, many times, no luck. Any help would be appreciated.
      • hellnbakH Offline
        hellnbak
        Doesn't anyone have some suggestions on why this is happening? If I lose the ability to use this plugin my life is going to get a lot more complicated! 😒
          If you post in the plugin's thread you are more likely to get noticed by the plugin author who will be albe to give you the best answer.
          • hellnbakH Offline
            hellnbak
            Jeez, I did not know that. I figured this would be the place to get help. Thanks.
              It's not a wrong place - but it's just more likely to get response in the thread of the plugin. Makes it easier to search as well when all the info is grouped in one place.
              • hellnbakH Offline
                hellnbak
                Good info. Will go into my ragged and tattered mental notebook πŸ˜†
