    Vray+Sketchup: texture on smooth surface
    4 Posts 2 Posters 1.1k Views 2 Watching
    • E Offline
      enea11
      Hallo!
      I'm using vray for sketch-up
      I try a lot of time to use texture on smooth surface, but I have always the same problem.
      You can see the file atthach: the texture ate not tile...
      I have read a lot of post, but I can find a solution... May be is a stupid problem, but I can't solve 😲
      Thanks for help! πŸ˜‰
      http://ilfaro.e20x.com/3d/wood test.jpg
      • ToboboT Offline
        Tobobo
        Hey,
        Have a look at the manual here http://software.asgvis.com/index.php?option=com_docman&task=cat_view&gid=443&Itemid=536
        On page 50 they show how to use texture mapping. One addition is for a smooth surface you have to turn the hidden geometry on so you cna adjust the texture as discribed in the manual.
        Hope it helps
        Toby
        Philippians 4:13
        • E Offline
          enea11
          @tobobo said:
          Hey,
          Hope it helps
          Thanks for your replay!!
          Yes, I have read the manual, but it can't solve... 😒
          In the mean time I have find a good solution here:
          http://forums.sketchucation.com/viewtopic.php?f=18&t=10762&hilit=texturing+organic
          This is my resut: I need to do better... I have to try β˜€
          http://ilfaro.e20x.com/3d/wood2.jpg
          • ToboboT Offline
            Tobobo
            Thats exactly what i was trying (although poorly) to explain.
            Toby
            Philippians 4:13
